#1 |
DWV PVC for Water Supply
DWV PVC: Can I use it for water supply from my new well to my new house? It is schedule 40 and is rated for 330psi. My flow calcs indicate that I need 1-1/2" pipe for supply, but the local big box hardware store only carries regular PVC up to 1" and everything over 1" is DWV PVC. Looking at the published specs for this JM Eagle pipe, there is no real difference between DWV PVC and PVC; am I mistaken? Thanks in advance for any help.
#2 |
Doing it myself
Not sure why DWV would be rated for such a high pressure....
![]() I can guarantee that it wouldn't pass an inspection, it's probably a bad idea.
Journeyman Plumber |
#3 |
My first thought was that it may be for use as a force main or for a pressurized line from a septic tank to a drain field. If it has a pressure rating that high, then I can't see why it wouldn't work
#4 |
Licensed Master Plumber
Work, yes. Pass code no. you can get the right stuff at any plumbing supply house. but why bother? 1 1/2 PE is available at home depot. Its less expensive and easier to work with and you won't have to play with couplings
Always ask to see your contractors license! |
#5 |
DWV piping is not suitable for potable water. I'm not sure the exact difference between PVC for drainage and PVC for potable water, but if you may get chemical leaching oders or other toxic effects from using the wrong type of PVC. I would only use PVC that was tested, rated and approved for use as potable water supply, which will be stamped with a laboratory seal or mark approving its use in potable water.
#6 | |
I=E/R
DWV PVC for Water SupplyQuote:
| Tags |
dwv, pipe, pvc, supply line ![]() |
| Display Modes | |
| New Faucets - Rural Water Well Supply | terra3 | Plumbing | 2 | 02-25-2010 06:41 PM |
| Extending Water Supply Box In Laundry Room | hsl | Building & Construction | 0 | 11-18-2009 10:21 AM |
| help w/ duct sizes & new supply locations | palex1915 | HVAC | 0 | 10-13-2009 08:52 PM |
| Galvenized supply to PEX, How to make connection? | twilightcall | Plumbing | 4 | 07-28-2008 10:28 PM |
| Supply Line Touching Roof | MikeinBurien | Electrical | 14 | 07-13-2008 12:26 PM |
