DWV - Busted Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-01-2008, 01:18 AM   #1
DWV - busted pipe
Hello,
I have a cast iron, maybe, pipe that busted under the house and needs to be replaced. I think I'm going to use PVC to replace it but I read about something about houses being grounded through the pipes. How can I tell if I need to use a jumper cable? Thanks for any and all input :-)
CSharkey is offline   Reply With Quote
Old 06-01-2008, 01:41 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
You may need more than a jumper, but check with your Building Inspection Department after making certain that your electrical system is actually grounded that way. You should be able to see it clamped to a pipe somewhere.
Mike
Mike Swearingen is offline   Reply With Quote
Old 06-01-2008, 01:52 AM   #3
Oh that is kind of silly I didn't think of that. Thank you.
Old 06-01-2008, 06:48 AM   #4
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
The cold water pipe coming into your house (if metal) ie. copper, galvanized, is bonded not the drain line.
wirenut1110 is offline   Reply With Quote
Old 06-01-2008, 09:21 AM   #5
I agree with Wirenut, I have never seen grounding on a waste pipe, only water (cold) supply lines.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 06-01-2008, 04:30 PM   #6
Thanks for the reply guys. My husband doesn't want me to fix it now, he's decided to have a professional do it. No faith, I tell ya!
Old 06-01-2008, 07:13 PM   #7
Registered User
Termite's Avatar
Cast is pretty easy to fix, especially with Fernco's!
For the record, you don't have to run a grounding electrode conductor to DWV pipes. Buried copper water lines, yes.
Old 06-01-2008, 09:28 PM   #8
Rewards Points: 510
Do it anyway and tell him what they charged and go on a little shopping spree with the money saved.
Backing off OLD galvanizd pipe...& PVC to cast iron michael76 Plumbing 13 02-17-2009 11:18 PM
Hooking New Bath into Sewer Pipe jasoncw Plumbing 4 03-04-2008 04:42 PM
PVC pipe broken on Gas Furnace/AC unit Keyo77 HVAC 8 10-16-2007 03:08 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
