DW Distance From Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-19-2008, 08:53 AM   #1
Rewards Points: 774
DW distance from Sink
We are in the planning stages of a kitchen remodel. Currently our dishwasher is adjacent to our sink (picture an "L" our sink sits on one length and then the dishwasher on the other). There is an 18" drawer space for access to water lines. The current set up has the DW draining into its own pvc drain. (It is not connected to the garabage disposal). I am struggling with 2 options.
1.) Keep the DW as is and run the drain into a new garabage disposal, providing that this distance is acceptable.
2.) Move the dishwasher next to the sink, which makes me have to move our peninsula 6" farther into an eat in space, tear up existing tile, and deal with the hassle of moving electric, plumbing, etc.
Can it stay as is, or should it be moved closer to sink?
cibula11 is offline   Reply With Quote
Old 03-19-2008, 09:42 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I'm not a pro plumber, just a long-time DIYer.
I see no reason why you can't leave the dw where it is and connect the drain hose to a disposal.
Just make sure that you install an air gap if one is required now by your local code, or loop the drain hose over the top of the dw before running it to the disposal. A dw pump should be fine at this short distance.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 07:07 AM
Can I tie the sink vent into the toilet vent? domgbrown Plumbing 4 01-11-2008 05:28 PM
Sink Depth dilemna Yippee Plumbing 9 01-01-2008 12:25 PM
Single Sink To Double Sink 39centstamp Plumbing 4 06-24-2007 10:27 AM
Fixing a sink - paint removed from the sink deb14905 Painting 2 04-18-2007 11:26 PM
