Durock Placed Along Tub Install - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-04-2012, 11:51 PM   #1
NNJ
Durock placed along tub install
I dd not silicone the underside of the tub onto the 2x4's underneath the tub.
The wallboard(durock) is placed over the tiling flange and curves towards the tub as it laps over the tiling flange causing flat-wall issues when it comes to tiling the wall. I'm thinking of cutting the durock along the flange on 1 side, the long side, silicone and then tile accordingly. However since I did not silicone the underneath don't know what to expect.
Should have done this research In advance. I'm seeking advice to remedy my problem to save my project. I have manage to remodel the entire bathroom and now this hickup. I'm in the tiling phase of the shower when I noticed this mistake. Thanks in advance
Nnj
NNJ is offline   Reply With Quote
Old 02-05-2012, 12:02 AM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Ive never siliconed a tub to the studs in the wall before ,I run a bead of caulk along bottem edge between the tub/tile and up the corners is all
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-05-2012, 12:09 AM   #3
NNJ
I will be doing that once I'm at that stage. However I was asking if I cut the durock along the flange to correct the flat wall issues from your opinion do you foresee a problem.
Thanks again.
Nnj
Old 02-05-2012, 12:11 AM   #4
plummen's Avatar
Like I said Ive never seen the need to do it in 30 plus years anyway
Old 02-05-2012, 07:48 AM   #5
DIY staff
Rewards Points: 7,174
Durrock should not be installed over the tub flange---backer rests on top of the tub flange---resulting gap is filled with thinset as the tile is installed---
No silicone is used in the installation of a tub or the Durrock--
Mesh and mud the seams and corners as you set the tile
Old 02-05-2012, 07:57 AM   #6
Rewards Points: 13,748
There would be silicone used at the tile to tub gap once the tile is set, not grout.
oh'mike (02-05-2012)
Old 02-05-2012, 08:35 AM   #7
Rewards Points: 528
I think the OP should remove the Durorock at the overlap and shim it some so the Durorock can overlap the tub flange.
Second guys you do not grout to the tub you silicone it.
framer52 is offline   Reply With Quote
Old 02-05-2012, 09:09 AM   #8
DIY staff
Durrock does not overlap the tub flange---set rock to the top of the flange---fill the gap with thinset as you tile---I think I said that already---
NNJ (02-08-2013)
Old 02-05-2012, 09:18 AM   #9
Rewards Points: 528
You did and you are still wrong.
ever been to the John Bridge forum?
Old 02-05-2012, 06:53 PM   #10
DIY staff
Yep--Been a member for years---lots of lousy info over there ---any body seems to have an option rather than expertise---then the place is reduced to arguments--
Who would drop the rock to the top of the tub? It causes a bent sheet of rock--if the entire wall is shimmed (furred) then the Backer board/drywall seam doesn't mate up---
So an experienced installer sets the rock to the top of the tub flange---
and fills the resulting gap with thinset as the tile is installed---or before if the walls are waterproofed before tiling.
paul100 (02-08-2013)
Old 02-05-2012, 06:58 PM   #11
DIY staff
Prove me wrong-----site a reference that is a respected authority--
You are new here and obviously not an experienced tile installer---
Show me a link .
Or a photo of your own work----
Old 02-05-2012, 07:47 PM   #12
Rewards Points: 528
Do you think that becasue my nic is referencing my previous occupation?
It referees to a point in time. Now I have installed many a piece of durorock and have read the instructions in how to install around a tub or enclosures. now be a good boy and go read the directions.
Second you never ever use grout to the tub. It will crack and with your method of leaving the durorock above the tub, allow water to penetrate behind into the wall ans onto the floor.
www.usg.com/.../installation.../durock-cement-board-installation-gui.
Now if you don't like that, how about tub instructions?
www.efaucets.com/.../pdf/bathtub%20installation%20instructions.pdf
Now I can't open PDF,s on this computer but trust me it is in there.
As to pictures, none handy of how to install.
as to your question of how to install without shimming the whole wall, my preference is to nail paint stir sticks approx 6 inches in length to the studs before installing the durorock'
now as to your final BS, I am 58 years old and until I was injured a few years ago spent little time online, unlike yourself. i worked and had a life.
Just become someone has many more posts does not mean you are correct. in fact, I joined a few years ago and quit because of the BS that was being spread. may have to quit again as a moderator should have more sense than to question someone and put them down with the BS you have used.
By the way, the John Brides forum is considered by people who actually work in the trades and want to make themselves better frequent. If you persist in inaccurate instructions again I implore you to visit and take to heart some of the posters guides.
If that is to much to ask, frequent the Contractortalk site, the sister forum to this one.
Old 02-05-2012, 08:01 PM   #13
DIY staff
Your links didn't work---shimming with a paint stick would throw the rock out of plane--the popular tiles of today 12x12 and larger require a flat wall--1/8 in 10 feet--or lippage will occur--
And a bulge will rise where the shirt meets the top---how do you address that ?
Old 02-05-2012, 08:21 PM   #14
Rewards Points: 636
i have done it both ways and it is an opinion on which way is best but all cement board manufacturer to my knowledge recommend a 1/4" space between tub deck and board and i always waterproof membrane paint all walls full height of tile, or membrane it schluter kerdi system but it is more costly
john bridge is a recommended site by the tile association but just like this sight it is full off opinions and some i agree with and some i do not due to my experience in the field because what i have seen during repairs and remodels one thing i highly do not recommend is putting plastic up over vapor barrier insulation before cement board due to the amount of mold growth i have seen becuase of moister trapping between the two off them if you fill the need for that extra precaution use a breathable moisture barrier like roof felt or house wrap
http://www.familyhandyman.com/DIY-Pr...e/Step-By-Step
jaydevries is offline   Reply With Quote
The Following User Says Thank You to jaydevries For This Useful Post:
Old 02-08-2013, 05:24 PM   #15
NNJ
Thank you everyone.
Thank you for your help.
OSB to durock install acfrqflyer Flooring 26 01-05-2014 04:32 PM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 10:00 AM
Aprilaire 560 Install Questions MisterTFM HVAC 4 12-15-2011 12:35 PM
Help with new construction window install pac127 Windows and Doors 1 09-26-2011 08:36 AM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
