Duplicate Pressure Reducers? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-02-2010, 03:41 PM   #1
Rewards Points: 111
duplicate pressure reducers?
Poking around our new house and I see not one, but two pressure reducers...inline, about 3 feet apart, 2 feet down from the water main. what gives?
Does a second reducer do anything more than the first one already does?
redline9k is offline   Reply With Quote
Old 12-02-2010, 04:28 PM   #2
Whenever I install a PRV there are instructions in the box for a double prv system. If the incoming water pressure is really high, say 150 psi, they would set the first at 120 and the second at 80. Or one of them went bad and they just stuck another one inline?
broox is offline   Reply With Quote
Old 12-02-2010, 05:00 PM   #3
Rewards Points: 111
main side is 120, and output side of the second is about 55....do you need two PRV to achieve a 65psi drop?
Old 12-02-2010, 05:09 PM   #4
I don't know if you "need" two but I would bet that those two will last longer than one would twice.
Old 12-03-2010, 06:21 AM   #5
Just call me Andrew
Rewards Points: 1,020
My parents' house has about 160 incoming PSI, they use a single watts PRV to reduce to about 55 PSI. The prv did eventually break....after 30 years.
Andrew
secutanudu is offline   Reply With Quote
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 06:04 AM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 12:59 PM
Older air compressor wiring help lash-1295 Electrical 91 12-23-2009 12:46 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 06:14 PM
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 09:50 PM
