Dual Water Heaters - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-03-2013, 03:40 PM   #1
Dual Water Heaters
I currently have a 50G Water Heater (6 years old) in the far end of my house which does an ok job of keeping up with our needs. Downside is it takes a long time to get hot water to the far end of the house and we do run out occasionally when multiple showers happen.
When I finished my basement I ran copper and electric to put the heater in a more central location. I also installed a valve to separate the hot water going to kitchen and kids bath from master bath and downstairs bath. So now my electric company has a $525 rebate on water heaters and I have several option and have no idea what's the best choice.
1) Replace the current 50G with an 85G
2) Install new 85G in new location, running both in parallel until 50G dies.
3) Install new 85G in new location, and run isolated systems until 50G dies.
4) Install new 50G in new location and plan on running two heaters forever either parallel or isolated.
Thoughts?
bluto1221 is offline   Reply With Quote
Old 03-03-2013, 04:05 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
I would install the new WH in the central location and remove the other.
Coastal South Carolina
Old 03-03-2013, 10:45 PM   #3
Rewards Points: 1,706
If you find that a 50 gallon HWT meets your needs why would you want to pay to heat an additional 35 gallons of water?
Oil Burner/Boiler & Tankless Water Heaters rjordan392 HVAC 6 01-01-2013 08:16 AM
Twin Water Heaters Installed BigD9 Plumbing 6 04-08-2012 02:06 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Tankless Water Heaters Recalled for Repair Due to Carbon Monoxide shimp Plumbing 1 01-22-2008 07:52 PM
