Old 06-08-2009, 07:07 AM   #1
Dual Sump Pumps: Rack to stack one on top of another?
Has anyone ever seen any sort of "rack" (or something) to easily stack 2 1/3 HP sump-pumps (one above another) in a sump crock that is too narrow to have them sit on the bottom side-by-side?
I've currently got a 12V backup sitting on top of a 1/3 HP sump-pump, but I'd rather have dual 1/3 HP pumps. The 12V pump is rather "weak" by comparison, though it has worked OK since I installed it a few years back.
BTW, I like to use Zoeller pumps.
bassman99 is offline   Reply With Quote
Old 06-08-2009, 04:19 PM   #2
DIY'r
ScottR's Avatar
Not sure of any pre-made products, but..
In the DIY spirit, I'm thinking a small (sturdy) trash can, upside-down, with lots of 1" holes drilled all over. Something that would fit over the bottom pump, with the top pump sitting on the underside of the can.
ScottR is offline   Reply With Quote
Old 06-10-2009, 08:33 AM   #3
Clever! I'm going to measure again to make sure I can't place the pumps "side by side", but if I "stack 'em", your idea sounds good!
Old 06-11-2009, 05:01 PM   #4
DIY'r
ScottR's Avatar
Heheh, thanks.. If you do end up doing it, post a pic and let me know if it actually works out!
Old 06-26-2009, 03:13 PM   #5
Smile
Take a look at the stainless steel hanger that can be used for a backup or a secondary electric sump pump to stack one above the other in any size sump. www.basepump.com/sump_pumps.htm shows a Pump Mounting Kit (PMK) to use exactly this way.
Pumpguy is offline   Reply With Quote
Why do sump pumps have 2 cords? abefroman Plumbing 1 02-19-2009 11:15 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
Sump Pumps RobertS Plumbing 3 02-22-2008 03:34 PM
Question about sump pumps and check valves lennyseleven Plumbing 3 11-08-2007 11:33 AM
DWV Stack Question dcgray2 Plumbing 9 07-14-2006 01:56 PM
