Old 06-07-2010, 03:20 PM   #1
Professional Wood Shafter
ryanh's Avatar
Dual Pressure tanks.
Hello. I have about 30" height clearance in my crawlspace. My 1/2 HP pump is rated at about 14gpm. The biggest tank i can fit standing up is a 26gallon with a 8gallon drawdown.. Pump theory says pump should run for aruond a minute so can i add a second pressure tank? How would you hookup 2 pressure tanks in one setup?
ryanh is offline   Reply With Quote
Old 06-07-2010, 03:37 PM   #2
You can install another pressure tank anywhere it will fit but preferably before any branches to different parts of the house.
Don't forget, after the tank pressure is calibrated and the system turned on and the pump has stopped, some of the space in the (each) tank will still be full of (compressed) air.
After the pump has stopped and when no one is using water, the pressure (in psi) is the same everywhere in the system from the faucets to the tanks to the pump output.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 06-07-2010, 04:22 PM   #3
ryanh's Avatar
I have room for an extra tank right beside the first tank. I'm just wondering how you would hook them up. Would they be hooked up in a series. tank 1 > tank 2 > discharge. or would i have to put a T or something after my pressure switch to both tanks, and then put a T to make it back into 1 line??
Old 06-07-2010, 05:15 PM   #4
Doesn't matter whether in series or parallel. You only need one air pocket to operate the pressure switch.
Old 06-07-2010, 06:40 PM   #5
Suggest arranging the tanks so water cannot become trapped in either one.
It is okay if the tanks have separate tee connections to the main pipe.
Old 06-07-2010, 10:48 PM   #6
ryanh's Avatar
Alright . Thanks dudes!
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 07:04 AM
Older air compressor wiring help lash-1295 Electrical 91 12-23-2009 01:46 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 10:50 PM
water pressure tanks metal vs fiberglass elementx440 Plumbing 2 04-11-2007 10:50 PM
