Dual 40 Gallon Hot Water Tanks - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-24-2011, 02:29 PM   #1
Dual 40 gallon hot water tanks
We have a 2500 square foot house with 2 1/2 baths. House is 11 years old and the original gas hot water tanks are both 40 gallons. Both original tanks are plumbed in series. What are the advantages of having 2 hot water tanks over 1 that is maybe 80 gallons?
sbauman4 is offline   Reply With Quote
Old 04-24-2011, 02:46 PM   #2
Plumb or Die!
It's crucial that when you're using two hot water heaters, they are plumbed in parallel, and all the piping is symetrical. Otherwise, due to water naturally taking the path of least resistance, one of the heaters does all the heating, and the other is just a storage tank.
One big tank is likely a better scenario than two.
plumber666 is offline   Reply With Quote
Old 04-24-2011, 03:27 PM   #3
Experienced
Jackofall1's Avatar
The advantage recovery time, unless you are going to purchase a $3000 80 gallon unit there is more BTU's total with 2 x 40 gal residential units.
Piping in parallel is one way to do it, there are many opinions on that one though.
Mark
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
