Drywall Or Denshield Behind Shower Walls? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-20-2006, 12:43 PM   #1
Drywall or Denshield behind Shower Walls?
I am installing an acrylic shower in a basement bathroom with metal studs. What should I put between the shower walls and the studs? Regular drywall, DensShield, Durock?? The guy at Home Depot told me I could put the shower walls directly against the metal studs. Sounds like a moisture problem waiting to happen. Also, depending on what I use should I put a vapour barrier behind the backer? One of the walls where the shower will be installed is an exterior wall so it is insulated and has a vapour barrier.
atilla137 is offline   Reply With Quote
Old 10-20-2006, 04:15 PM   #2
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
Actually, to the best of my knowledge, I think the home depot gentleman has it right.
Those tub/shower units are designed to mount directly to studs. Some furring maybe needed, but not durock or anything. If you are anticipating moisture getting behind the wall of your shower, you've got other problems.
J187 is offline   Reply With Quote
Old 10-20-2006, 05:06 PM   #3
I agree, the drywall goes over the lip of the unit to finish off the walls, nothing behind it, unless it's those thin glue on panels, which in my opinion is a waste of time if it is.
R&D Tile is offline   Reply With Quote
Old 07-20-2008, 09:11 AM   #4
HomeAdditionPlus.com
Rewards Points: 29
You should be able to attach the shower assembly directly to the framing. Then apply greenboard (Waterproofed type drwall) over the lip of the shower unit.
Last edited by AtlanticWBConst.; 07-20-2008 at 12:54 PM. Reason: DIY Chatroom Rules Violation: Site Link Removed
mjdonovan is offline   Reply With Quote
drywall onto uneven walls? johnny331 Remodeling 5 06-28-2007 07:59 AM
Durarock or Denshield for shower? efisixpack Building & Construction 19 12-04-2006 10:59 AM
Maxx Shower Walls Install on Metal Studs? atilla137 Plumbing 2 11-21-2006 06:17 PM
Bathroom Ceiling and Walls. Drywall ok? atilla137 Building & Construction 11 10-26-2006 03:32 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 05:33 PM
