Dryer Vent - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-22-2009, 06:16 PM   #16
I'd be leary of using a booster fan with the lint in the air, but along the same line of Dave trying to help out, maybe consideration of moving the laundry room. Not a simple thing to do, but you can check on your options. As stated earlier, you just want to be safe.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 11-22-2009, 06:19 PM   #17
Originally Posted by Michael Thomas View Post
The instructions for every electric dryer I've seen (except for condensing units) includes the following:
Yeah, there's also about 14 different warning labels on ladders
Plus a warning on matches to close cover before striking a match
Then of course the warning on cigarettes that they "may" cause cancer
It's all about a companies liability in denying fault
Old 11-22-2009, 07:27 PM   #18
Registered User
Rewards Points: 5,180
Booster fans are no longer accepted to make a longer run than code or man. instrs., as of 2006, IRC, M1502.6.
Cyhm, look up your dryer's instructions on their web page, some allow longer runs. Also the new code allows longer runs with sweeping 45* and 90* bends. Check into venting through the roof, or at least install a smoke detector in the room and only use the unit when home. (hint: use stainless steel washer supply hoses rather than rubber ones, less insurance claims). I wonder if the H.A. will pay for the damage from a dryer fire when your homeowner's policy doesn't because the installation is not to code.
Be safe, Gary
Old 11-26-2009, 01:13 PM   #19
The dryer in question is electric. I just had my washer and dryer(front loaders)moved to the second floor. I was more concerned with the moisture issue. My windows get condensation on them, even downstairs. It does keep the second floor nice and toasty though. Good for winter time, not so much for summer, we'll see.
fuzbutz4 is offline   Reply With Quote
Old 11-26-2009, 05:14 PM   #20
Chicago, IL
Michael Thomas's Avatar
The fact remains that following code and the manufacturer's installation instructions is the best - and sometimes the only - way to protect yourself from liability and declined insurance claims.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Please look at this dryer vent installation Andy Griffith Appliances 6 08-31-2009 01:39 PM
very clogged dryer vent. Not just lint catman Tools 4 04-20-2009 05:48 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 05:26 PM
Help, how & where can I vent a 2nd floor dryer? jaes Remodeling 2 06-28-2008 11:03 AM
Dryer vent. kcrossley2 Plumbing 10 02-20-2008 01:02 AM
