Dry Well Venting? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-10-2011, 03:38 AM   #1
dry well venting?
hello, I recently had some decorative concrete curbing/edging installed along my entrance concrete walkway and now the water puddles up when it rains heavy. There's no other way to get rid of the water so I installed a 1" channel drain in the walkway and fed it through a 1" pipe to a buried 5 gallon bucket that I drilled holes in and put crushed stone around.
i think this is called a dry well. Filling the bucket with water perks really good since it's in sandy soil. The problem I have is when the drain is completely covered with water it seems to create a vacuum so I need to vent it. Would it be best to vent the bucket with a pipe or vent the drain pipe with a T fitting and a pipe. I'm not sure if the drain pipe would vent properly if it is filled with water. Hope this makes sense. Thanks for any help.
manny2b is offline   Reply With Quote
Venting ponch37300 Plumbing 41 02-23-2013 11:37 PM
Venting a sink pump WillK Plumbing 2 12-26-2010 02:21 PM
Gas furnace venting Qs (non high eff) WallyWoggle HVAC 6 12-09-2010 07:41 PM
I want to maximizing venting, diagram included. cbzdel Roofing/Siding 3 07-28-2010 05:55 AM
Soffit venting vs. DCI Smart Vent JDPII Roofing/Siding 1 02-28-2009 09:42 PM
