Old 06-07-2011, 12:37 AM   #1
dry water line to the foot valve
I just replaced my pump for what was probably a bad foot valve. I replaced the foot valve and now I am having trouble priming the pump. I have tried several times. I was wondering, if when I took the foot valve off I lost the prime to the line and need to fill it with water also bfore it will prime the pump. I know what the foot valve does, but if there is no water in the line it may not be able to help prime the pump. Thank you for any insight.
ksbnellis is offline   Reply With Quote
need help finding a selenoid actuated ball valve to control "circulation line on HWH tominator Plumbing 1 03-29-2011 10:46 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 10:26 PM
