Dry Fitting ABS - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-09-2007, 01:12 PM   #1
Rewards Points: 93
Dry fitting ABS
Is there a product you can use to dry fit ABS pipe but make it easy to put in and take it? I was thinking of using either cooking oil, KY gelly or even vasoline but didnt know if it would intefeer with the glue afterwards
simonb is offline   Reply With Quote
Old 09-09-2007, 01:39 PM   #2
If you really need to dryfit, I would suggest the K-Y. It is water soluble and could be washed off before permanent installation. Oils and vaseline would/could leave residue that will interfere with adhesion. Best is still to measure the pipe and fittings.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 09-09-2007, 01:46 PM   #3
Rewards Points: 93
Your right, it is. But when you have to do 4 odd angles and drops, its hard to get it right on the button. Does it matter if the pipe isnt pushed all the way into the peice, im not saying i would just push it in 1/8 into it, but i mean about 3/4 way into the fitting
Old 09-09-2007, 02:33 PM   #4
Since it not a question of length dimensions but angles, you should be able to slip the pipe and fittings in far enough without any lube and then mark the positions on the side or the pipe and fittings with a Sharpie marker for assembly. If this doesn't work, go with the K-Y. Good luck on your project.
Pex/Qest Compression Fitting Logback Plumbing 9 09-03-2010 09:32 PM
Connecting PVC to Galv Pipe fitting for Drain froddan Plumbing 19 02-28-2010 03:33 PM
which way to cut baseboards for inner angle fitting? KUIPORNG Carpentry 22 05-30-2007 02:26 PM
Help, the bakelite light fitting in my shower room smells! Unregistered Electrical 1 08-13-2004 07:03 AM
