-   -   Dry fitting ABS (http://www.diychatroom.com/f7/dry-fitting-abs-11397/)
simonb 09-09-2007 01:12 PM
Dry fitting ABS
Is there a product you can use to dry fit ABS pipe but make it easy to put in and take it? I was thinking of using either cooking oil, KY gelly or even vasoline but didnt know if it would intefeer with the glue afterwards
majakdragon 09-09-2007 01:39 PM
If you really need to dryfit, I would suggest the K-Y. It is water soluble and could be washed off before permanent installation. Oils and vaseline would/could leave residue that will interfere with adhesion. Best is still to measure the pipe and fittings.
simonb 09-09-2007 01:46 PM
Your right, it is. But when you have to do 4 odd angles and drops, its hard to get it right on the button. Does it matter if the pipe isnt pushed all the way into the peice, im not saying i would just push it in 1/8 into it, but i mean about 3/4 way into the fitting
majakdragon 09-09-2007 02:33 PM
Since it not a question of length dimensions but angles, you should be able to slip the pipe and fittings in far enough without any lube and then mark the positions on the side or the pipe and fittings with a Sharpie marker for assembly. If this doesn't work, go with the K-Y. Good luck on your project.
