Drum Trap Covet - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-29-2010, 09:57 AM   #1
Drum Trap Covet
I nned to replace a leaky cover located in the basement under the upstairs tub. It looks failrly straitfoward but unsure of what kind of adhevise or glue I should use to secure the water from leaking between the threads. Is a standard plumbimg ggop sufficent on such things. As you can probably see by my use of words I am not a plumbler and not used to doing such projects. I purchased the cover at Ace but didn't even think of asking someone there.
Thanks, Jim
krawiszjm is offline   Reply With Quote
Old 04-29-2010, 11:42 PM   #2
try a 4" fernco jim cap. its a rubber cap with a big hose clamp. It will work perfectly.
plumber Jim is offline   Reply With Quote
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 12:46 PM
Keep cast iron trap or new ABS trap? thebigsee Plumbing 1 01-26-2010 04:18 AM
Drum trap, best to replace them? diymonkey Plumbing 4 06-04-2009 09:14 AM
Cat trap fever radtek General DIY Discussions 13 05-31-2009 07:18 PM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 11:10 AM
