Dropped In The Drain! - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-11-2011, 08:07 AM   #1
Dropped in the drain!
Hello,
I was replacing a toilet last night and had a mid-size measuring tape attached to my belt. It slipped from the belt and landed straight in the sewage drain. It happened too early for me to cover the drain hole. I tried pulling it out, but it disappeared. I ran water through the drain to check if it has clogged the drain, but the water seems to be flowing through. I've installed the toilet and water seems to be running through no problem. The drain pipe is 4" and should have enough space for the water to flow.
Should I just leave it there and hope it will get pushed out someday? Is there a way to remove it?
Thanks for your advice.
bill82 is offline   Reply With Quote
Old 07-11-2011, 08:16 AM   #2
DIY staff
Rewards Points: 7,174
That's likely to cause you some problems sooner or later-------
What's the plumbing like in the house? Iron--plastic---slab house or frame---first flood or second floor?
When the piping clogs you will need a plumber with a camera to find that---How big was the ruler?
Old 07-11-2011, 08:25 AM   #3
The drain pipe is clay and it occurred in the basement. The tape was 100ft. long.
Do they have a tool to catch it and pull it out if they locate it with a camera? I'm afraid of using the snake as it may push it out further and in the main pipe.
Old 07-11-2011, 08:42 AM   #4
DIY staff
That will be up to the plumber---likely the spot will be located and the area excavated and the object surgically removed.
Rotten luck---I have had a similar experience,but the piping was in a crawl space so cutting the pipe was all that was required.
There are several good plumbers here with camera experience----let's see what they have to say---
Hopefully soon---Mike---
Old 07-11-2011, 11:07 AM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
No magnets on that planet I suppose!!
Most tapes have some metal parts that would be attracted to a magnet.
XXX
Bathtub Drain Leak Help! jgcable Plumbing 54 12-19-2010 10:40 PM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
