Drop-in Tub Access Panel? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-29-2009, 02:52 PM   #1
Drop-in tub access panel?
Hello, I'm installing a drop in tub in a framed in tub surround. I'm getting ready to tile the tub surround and I'm wondering, do I need to put in an access panel? It's not a jacuzzi tub, so there is no electrical or motor that will need to be accessed. The tub will be sitting on a cement slab. Once the plumbing is hooked up and checked for leakage, I don't see a need for future access.
Any thoughts?
shilohtown is offline   Reply With Quote
Old 03-29-2009, 07:32 PM   #2
Access
Use your own common sense, someday , sometime, someone, will have to get to that setup , reason unknown but I know they will.
Leave an access to get at it.
SULTINI is offline   Reply With Quote
Old 03-29-2009, 11:17 PM   #3
Yes, you are correct. I was just finishing hooking up all of the plumbing and was thinking of everything that could start leaking, loosen up, etc.
I will be putting in an access panel.
Thank you.
Tags
access panel , surround , tub
Access Panel or Door for Shower Plumbing Any pics? twilightcall Plumbing 4 12-22-2009 06:53 AM
Finishing off access door panel TanMan Building & Construction 12 02-05-2009 06:59 PM
Apartment - Access to Panel Box? silver26 Electrical 3 08-07-2008 10:56 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
