Drop In Soaking Tub - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-10-2013, 12:05 PM   #1
Drop in Soaking Tub
I'm remodeling my bathroom and will be replacing the drop in soaking tub. The old tub was installed by the builder, and construction adhesive was used to secure to the floor.
The new tub has the following instructions: The bath must be supported along its entire bottom. Use mortar as bedding material (do not use sand or foam). Apply enough mortar to support the complete bottom of the bath.
The question I have, is how thick should I make the mortar base?
Also the deck height is 20.5" for the tub, and I'm assuming I should add to the deck height the thickness of the mortar base. Otherwise if I build the tub deck exactly 20.5", all the mortar would squeeze out entirely from beneath the tub.
Or does the manufacturer deck height installation of 20.5 already take into account the use of a mortar base, and no additional deck height is needed.
Jim
jibennett is offline   Reply With Quote
Old 03-10-2013, 02:30 PM   #2
measure the tub and see what the actual height is. then you can adjust the deck height for the mortar under it.
Old 03-10-2013, 05:44 PM   #3
MarginallyQualified
Rewards Points: 2,464
Eliminate the D-I Garden Tub altogether.
Go for the MEGA shower instead.
Basement - drop ceiling jgrohol Building & Construction 11 04-01-2011 12:39 PM
Could I move my Meter & Power Drop to the Side of my house? jamiedolan Electrical 9 07-28-2010 05:16 PM
Drop Rate on Scott's Drop Spreader SPS-1 Landscaping & Lawn Care 1 04-28-2009 08:24 PM
Drop Ceiling Prices? bengbrewer Remodeling 8 03-18-2009 02:00 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
