Drop For Sink Drain, Does It Need To Be .25"-ft The Whole Length? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-22-2012, 06:49 PM   #1
Rewards Points: 12
Drop for sink drain, does it need to be .25"-ft the whole length?
Question from a DIYer new to plumbing.
I'm installing a bar sink in a spare room in my basement and the closest spot the sewer line in the house is exposed is about 16' away. Based on the standards I'm going to be using 1.5" DWV ABS pipe and know that the drop I'm supposed to use is .25" per foot.
The issue that I have is that there is a bathroom between the room I'm doing the installation and the main line. Based on the drop, the toilet tank is too close to the wall and will prevent me from installing the pipe outside the wall and boxing it in (the wall is an exterior wall and my understanding is that code forbids the pipe from being installed inside an exterior wall, presumably due to the risk of freezing and/or condensation.
This said, what is the best option for installing the pipe? Can I tie directly into the outlet under the toilet, raise the toilet, change the drop from 1/4 to 1/8 for the last section, buy a new toilet with a higher base?
Suggestions more than welcome!!!
Thanks!
dblade is offline   Reply With Quote
Old 10-22-2012, 06:57 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 540
A sink needs a 2" drain line, not 1.5"
The trap arm after the vent can be 1.5"
1/4" per ft is minimum grade for 2" pipe
You can pipe in an exterior wall if it's in the basement- it wont freeze and is non bearing
You might be able to pipe the sink to the toilet vent- need more info from you, such as how its piped now
Old 10-22-2012, 07:25 PM   #3
Rewards Points: 12
Thanks for the response, I'll likely end up removing the toilet and opening the wall to see how its vented now, with nothing exposed I have no idea, and frankly am curious myself...
After I've done that I'll sketch it out and post it.
I'm kind of confused that you've indicated a need for a 2" pipe on a sink, everything I've read so far, including the Ontario Building code (Table 7.4.9.3) seems to indicate 1.5" is fine for a regular domestic sink unless you have a garbage disposal on it?
Old 10-22-2012, 07:29 PM   #4
Plumber
Rewards Points: 540
Codes do vary. UPC states sinks are 2" (and need a clean out)
Trap arms may be 1.5"
Old 10-22-2012, 07:54 PM   #5
Rewards Points: 636
can you tye into the sink in bathroom
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 10-22-2012, 09:21 PM   #6
Rewards Points: 12
Unfortunately not as the sink is on the opposite side of the bathroom. I've posted a rough layout to make it clearer.
Drop for sink drain, does it need to be .25"-ft the whole length?-layout.jpg
Old 10-22-2012, 09:25 PM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Is it in this thread? It's not showing up for me.
Oh, I commend you on your ninja edit.
Journeyman Plumber
Old 10-22-2012, 09:27 PM   #8
Doing it myself
Alan's Avatar
Does the waste and vent stack exit the building near where it goes into the slab? You could always run the drain outside of the building and tie into the building drain in the yard.
Journeyman Plumber
Old 10-22-2012, 10:02 PM   #9
Rewards Points: 12
No luck with that option at all, the line runs under the slab to the front of the house. I'm in Ontario, Canada, so no real option for an exterior tie in. Had a contractor give me a ball-park price for chipping the slab and doing a tie in in the room where the sink is going and he was figuring about $1200 (old cast iron main pipe under the house) so not even remotely cost effective
Old 10-22-2012, 10:05 PM   #10
Doing it myself
Alan's Avatar
Couldn't you tie into the main stack below grade, and run it outside of the building anyway?
Journeyman Plumber
Old 10-22-2012, 10:13 PM   #11
Rewards Points: 636
here it goes get ready for a war i have ran a lot of under 3" pipe at 1/8 per a foot under only way to make it work and it has always worked
Old 10-22-2012, 10:27 PM   #12
Plumber
Rewards Points: 540
And I've used pumps in this type of situation too
Old 10-22-2012, 11:08 PM   #13
Rewards Points: 12
Hmmm... pump might be worth a shot... @jaydevries, from what I've read you've likely been fine with the 3" pipe at that drop since the pipe is unlikely to ever fill up entirely with water... though if I have to start putting 3" pipe in to deal with a little bar sink I'm going to make all future holes in the wall by banging my head against them
Old 10-23-2012, 01:12 AM   #14
JOATMON
ddawg16's Avatar
Rewards Points: 1,444
Not trying to hijack the thread....
But to confirm....ALL sinks have to go into a 2" drain? Even bathroom sinks?
I was under the impression it could be 1 1/2".
Old 10-23-2012, 03:49 AM   #15
Thread killer
Rewards Points: 272
The OP is in Ontario, Canada. We can run our kitchen and shower drains in 1.5", provided you have a minimal fixture unit.
You can have it good, fast or cheap. Pick two.
Canucker is offline   Reply With Quote
Central Air Secondary Drain Leaking - 3 questions walters_12 HVAC 7 05-11-2011 03:20 PM
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 06:52 PM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
Drop in bath tub center drain to lft drain mikerich28@hotmail.com Remodeling 1 04-16-2008 08:48 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
