Drop In Corner Tub With No Base And Little Support - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-05-2009, 06:55 PM   #1
Drop in corner tub with no base and little support
Is it normal to have a hole with dirt under your tub? Anyone know how to make this arrangement normal? The tub surround was only attached with silicone..Would a tub in this condition cause a house not to sell?
Drop in corner tub with no base and little support-smaller-size.jpg   Drop in corner tub with no base and little support-smaller-size-3.jpg   Drop in corner tub with no base and little support-smaller-size-2.jpg
monetzpond is offline   Reply With Quote
Old 04-05-2009, 07:24 PM   #2
Remodeling Contractor
The hole is normal. The tub drain is below the unit and can only be put together if this hole is there to work on it. Some tubs need support along the upper rim, some need a bed of plaster or motar but some need nothing.
Old 04-06-2009, 08:28 AM   #3
Rewards Points: 5,336
I would have framed a wall behind the acrylic panels that went all around the tub. That installation is incorrect. There is currently no support if you sit on the edge.
The hole is normal for slab installations. You can cut a piece of cement board or hardie board to clean up the look if you want.
Ron
