-   -   Drop in corner tub with no base and little support (http://www.diychatroom.com/f7/drop-corner-tub-no-base-little-support-41875/)
monetzpond 04-05-2009 07:55 PM
3 Attachment(s)
Is it normal to have a hole with dirt under your tub? Anyone know how to make this arrangement normal? The tub surround was only attached with silicone..Would a tub in this condition cause a house not to sell?
Bob Mariani 04-05-2009 08:24 PM
The hole is normal. The tub drain is below the unit and can only be put together if this hole is there to work on it. Some tubs need support along the upper rim, some need a bed of plaster or motar but some need nothing.
Ron6519 04-06-2009 09:28 AM
I would have framed a wall behind the acrylic panels that went all around the tub. That installation is incorrect. There is currently no support if you sit on the edge.
The hole is normal for slab installations. You can cut a piece of cement board or hardie board to clean up the look if you want.
Ron
