Driveway Sump Pump Clogged With Mud! - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-26-2010, 05:44 PM   #1
Driveway sump pump clogged with mud!
Hi! So my driveway (which slopes toward the house) had a drainage system that was decades old and has now completely disintigrated. It was a clay pipe and is now not a pipe at all, just dirt and roots. I was told that the only way to put a new pipe in would be to dig up the driveway and install a new one.
An alternative was suggested of installing a drain attached to a sump pump instead, so that's what I did. For the most part, it works ok, but it has been collecting mud and little bits of things that get down the drain. It clogs up the intake on my sump pump, defeating the whole purpose and driving me crazy. Any advice on how to keep it clean?
Thanks!
--Chris
sillyboy22 is offline   Reply With Quote
Old 07-26-2010, 06:05 PM   #2
Rewards Points: 6,652
Who told you to use a sump pump in a mud pit? The only way is to slope the ground away from the drive, while pitching the drive the proper way to allow for run off of water out to the yard.
Tags
sump pump driveway mud
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 07:46 AM
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
Sump Pump for Driveway cibula11 Plumbing 12 03-04-2008 02:20 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
