Driven Well - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-12-2012, 11:17 PM   #1
Driven Well
I have a 2" galv driven well pipe with a steel cap stuck on it! The 2" galv has threads, but I think they are stripped. The steel cap just keeps spinning on top of the pipe. I know that I could cut off the galvanized pipe, but I don't have any way of redoing the threads once I cut it off if needed. I was wondering if a sawzall with a metal cutting blade would cut the drive cap off or if there is an easier way.
Thanks,
Jen
Frog2221 is offline   Reply With Quote
Old 08-12-2012, 11:38 PM   #2
Rewards Points: 12,808
Even if you did get the cap off now the threads are shot. It will have to have a tight seal or the pump will not be able to draw water out of the pipe.
The pipes going to have to be cut with a pipe cutter not a sawsall and be rethreaded.
Pretty sure a real plumber will have what's needed.
Tags
cutting , driven well , galvanized pipe , sawzall
non-electric ceiling fan??? bobrok Green Home Improvement 98 07-13-2015 05:19 PM
Replace Screw driven Garage door opener? knotquiteawake General DIY Discussions 7 06-03-2012 09:35 PM
Garage subpanel problem Schlominator Electrical 13 10-02-2011 09:15 AM
Why HVAC install shouldn't be price driven unicursalhex HVAC 32 05-13-2011 03:29 AM
Driven to DIY in desperation Rachel39 Introductions 1 01-28-2010 06:05 PM
