Drive Point For Irrigation - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-22-2010, 10:44 PM   #1
Drive point for irrigation
I used a 1 1/4" drive point tied into a 2" galvanized pipe got down to about 18' with 5' of water. The problem is that I always lose the prime, despite having a foot check. The pipe doesn't leak, and the foot check does seat. But if the system stays off for more than an hour or so, I have to re-prime.
I am considering boring 6" abs pipe in order to install a 4" submersible pump.
Any thoughts would be appreciated.
This setup is strictly for irrigation purposes (ours).
Flashheatingand is offline   Reply With Quote
Old 06-23-2010, 02:53 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Install a check valve on the suction (well) side of the pump up near the pump to hold prime if your foot valve isn't.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
Drive Point Well for Sprinkler System? tigerbalm2424 Landscaping & Lawn Care 0 06-03-2009 06:40 AM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
Drive Point Well for Sprinkler System? tigerbalm2424 General DIY Discussions 4 05-20-2007 11:38 AM
