-   -   dripping from water shut off valve underneath the toilet (http://www.diychatroom.com/f7/dripping-water-shut-off-valve-underneath-toilet-5303/)
maitri 12-09-2006 10:22 PM
I had to replace fill valve cap in my toilet tank as water was continuously running from it. It stopped after I replaced the cap but while doing this I had to shut off the water supply to tank. While turing back on the water suppy, I noticed water started dripping from it. Is there anything I could do to stop it.
mdshunk 12-09-2006 11:48 PM
It is very likely leaking from the "packing nut". It is the nut that surrounds the stem of the valve. Often, giving it a very slight tightening with a Crescent wrench will stop the drip. Don't go too hog wild, or you'll bust something and flood your place. Just a little snugging is what you're aiming to do.
http://www.hammerzone.com/archives/b...g/batwr35s.jpg
mdshunk 12-09-2006 11:50 PM
Here's an article on that topic:
http://www.rd.com/content/openConten...ontentId=19461
Bonus 12-10-2006 03:02 AM
sometimes when you turn those back on, they will drip if you open the valve all the way, try closing it a quarter turn. Then do the packing nut tighten, then turn your water off and replace the valve.
maitri 12-10-2006 04:58 PM
Thanks for the suggestions. It really helped me. I will folllow the direction. Thanks again . :)
