Dripping Washer - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-15-2006, 11:56 AM   #1
Dripping washer
My washer started to drip water when off. At the end of day the washing tank is full. Any suggestions?
popkadurak is offline   Reply With Quote
Old 06-15-2006, 03:21 PM   #2
Rewards Points: 334
Could be the valve - unplug the machine - and follow the input hoses - they should come together at the valve. the ouput of this will go to the where the tub fills.
tribe_fan is offline   Reply With Quote
Old 06-15-2006, 10:13 PM   #3
Sciencerules
MAS2006's Avatar
Sounds like one of the valves is leaking. You did say washing machine tub fills with water? Determine if hot or cold by shutting off each supply in turn. With water off remove hoses from back of machine and check screens (most washers have them) for debree or scale build up(will cause valve to stick open). Use care some makes are plastic parts. If machine over three years old the rubber part of valve maybe bad and require replacing.
MAS2006 is offline   Reply With Quote
Washer drain peloncito Appliances 7 08-04-2007 01:56 AM
Is it possible I have a 220 running to my dish washer? aljanney Electrical 25 02-15-2007 11:08 PM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 10:16 PM
increasing washer supply lines to 3/4" instead of 1/2" amatchin Plumbing 3 04-15-2006 05:23 PM
