-   -   Dripping washer (http://www.diychatroom.com/f7/dripping-washer-2759/)
popkadurak 06-15-2006 10:56 AM
Dripping washer
:)My washer started to drip water when off. At the end of day the washing tank is full. Any suggestions?
tribe_fan 06-15-2006 02:21 PM
Could be the valve - unplug the machine - and follow the input hoses - they should come together at the valve. the ouput of this will go to the where the tub fills.
MAS2006 06-15-2006 09:13 PM
Sounds like one of the valves is leaking. You did say washing machine tub fills with water? Determine if hot or cold by shutting off each supply in turn. With water off remove hoses from back of machine and check screens (most washers have them) for debree or scale build up(will cause valve to stick open). Use care some makes are plastic parts. If machine over three years old the rubber part of valve maybe bad and require replacing. ;)
