Old 05-09-2010, 01:42 PM   #1
Dripping from NEW pressure rreduction valve
My Mom had some work done at her house about a year ago.
She said she has never turned the water back on after the construction.
She has been living elsewhere.
I went to turn on the water at the brand new off-on valve and about a foot away from that is a brand new conbraco 36c-904 pressure reducing valve that drips like crazy out of the adjustment bolt. Nothing I did stopped the drip. I took the bolt completely out and tried reinserting it again but it still leaked like crazy. I'm guessing that this is not normal for a NEW piece of equipment. Any suggestions? Replace the unit? Teflon tape? I doubt the contractor will come back out a year after the fact.
Any help is appreciated folks.
woody11 is offline   Reply With Quote
Old 05-09-2010, 01:44 PM   #2
retired elect/hvac/plumb
plummen's Avatar
sounds like warranty issue to me,call the plumber back
plummen is offline   Reply With Quote
Old 05-09-2010, 01:47 PM   #3
Even after a year has passed from when he did the work?
The warranty will cover the cost of the valve... but not labor?
Old 05-09-2010, 01:53 PM   #4
plummen's Avatar
not all of us plumbers are as cold hearted as people think,give him a call and see what he says first
Old 05-09-2010, 04:45 PM   #5
Doing it myself
Alan's Avatar
Journeyman Plumber
Old 05-09-2010, 08:04 PM   #6
Thanks Guys, I'll make the call tomorrow. But just in case,
can these be repaired? Why would it leak and would teflon tape on the bolt help? Replace the valve? Just in case...
Old 05-09-2010, 09:23 PM   #7
Household Handyman
IMO- -The diaphragm inside the PRV has dry-rotted from just sitting there, and probably with pressure on the adjustment screw side. Some PRV's can be re-built. But, this usually takes longer than replacing them. Call the plumber who did the job. David
Old 05-09-2010, 09:56 PM   #8
Doing it myself
Alan's Avatar
You shouldn't have to teflon tape the bolt. The ones we use made by watts have rebuild kits available for them and are actually easier to rebuild than removing the darn thing, ESPECIALLY if it's buried in the ground.
Journeyman Plumber
Old 05-09-2010, 10:17 PM   #9
Thanks. I'll see what what he says.
If he doesn't extend any warranty, I would understand. It did sit there an entire year.
Again, Thanks Folks
How to diagnose gas valve problems Nestor_Kelebay How To Guides 27 03-07-2013 03:17 AM
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 06:32 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 08:48 PM
