Drip Emitter Septic System - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-08-2014, 09:19 PM   #1
Just bought a house. been here a week and the septic tank started overflowing into the yard. Fortunately the tank is lower than any pluming so it is leaking out into the woods beside the house.
So here is what I have learned about my system. It has a large 2 part holding tank (600 gal). the liquid overflows from that tank into a 450 gal pump tank. The liquid is pumped from the pump tank directly to the drip emitter lines.
I drained the pump tank and found that the pump was not working. There were electrical splices inside the tank that had come apart. Who would have a flying splice submerged in atank?? Furthermore there is no all weather box,its just a piece of uf romex that comes through a hole in the tank.
To add to the confusion, the system has a well type pump in the bottom. Not a traditional submersible pump, a well pump. It had a float ziptied to the side with electrical wires spliced to the pump.
All of this was permitted by the county when the house was built in 1995. Does anybody know why a well pump was used. Is this something that is typically done in a drip emitter system? I have a wife and two kids who need showers, toilets etc. Any help would be greatly appreciated.
I have considered buying and installing a typical septic pump but I want to know if well pumps are sometimes preferred for this type of system.
By the way. I have the electrical circuit turned off and the pump (well pump) removed.
Thank you in advance,
Aaron
Aarone1972 is offline   Reply With Quote
Old 04-08-2014, 09:42 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 996
What state are you in.??
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 04-08-2014, 09:48 PM   #3
Rewards Points: 284
Some pumps used look like well pumps but they are for a septic tank. They are used to pump filtered water long distances better than traditional looking septic pumps.
http://www.septictankparts.com/Lift-...FY1xOgodQmUAnw
JustinK is offline   Reply With Quote
Old 04-09-2014, 07:06 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
I have a similar set up, but mine has a regular "Dose Pump" made to be submerged. It has a float switch to control it. There is also a second float switch wired to an alarm box in the basement, should the dose pump fail. The connections on mine were made sloppily by the installer. After a short time they corroded and everything quit. I mounted a water tight box on the side of the tank entry tube as high as possible and then respliced all the connections with sealed connectors. Been working for a dozen years or more with no issues. A regular shallow well puump would need to be mounted high enough to stay dry and need a foot valve to keep it's prime. An alarm circuit would be a must I would think.
Old 04-09-2014, 11:50 PM   #5
Owner
LateralConcepts's Avatar
Sounds pretty typical. You should post some pictures. How do you know it's a "well pump" and not a sewage/effluent pump?
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Tags
field line , pump , seepage , septic , sewage
cost of septic lagoon system chulett Plumbing 0 05-09-2011 09:51 PM
Aerator fuse for septic system. waynealan Electrical 2 04-16-2011 11:00 PM
drip irrigation system Master Brian Landscaping & Lawn Care 1 03-31-2011 10:20 PM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 05:23 PM
Sewer smell in sump pit (house is on a septic system) NateDogg1955 Plumbing 2 12-18-2009 05:01 PM
