#1 |
Drilling into concrete foundation to remove cast iron drain pipe
Does anyone know what exactly I would do to remove the cast iron from the foundation from the outside wall of the house. Would a jack hammer be the tool to use? I am worried about cracking the foundation or having cracks show up in other places in the house when I drill into it. I have already removed most of the cast iron from the wall. I just have this elbow piece that goes down into the foundation and under the house which comes out into the ground.
#2 |
Super Moderator
A picture would help---for delicate concrete work --you might do well to rent a concrete chipping hammer--this is like a hand held jack hammer.
You should be able to open up enough concrete to get out the old pipe and install a new one withou causing any big problems with your foundation.
New members: Adding your location to your profile helps in many ways.--M-- |
| Tags |
cast iron, concrete slab, foundation concrete, piping, plumbing fixtures ![]() |
| Display Modes | |
| Old School Cast Iron Pipe Repair | turkboy | Plumbing | 14 | 06-28-2012 07:50 AM |
| removing iron drain from foundation | osmotik | Plumbing | 15 | 04-04-2011 10:26 AM |
| Cast Iron Pipe | ehv8trix | Plumbing | 4 | 11-25-2009 07:49 PM |
| pouring concrete around cast iron pipe? | walkman | Plumbing | 1 | 10-16-2009 11:04 AM |
| Cutting Iron Drain Pipe | jonathan03 | Plumbing | 12 | 01-31-2009 10:33 PM |
