Old 03-17-2008, 07:30 PM   #1
drilling hole in sink
I need to drill a hole in a white kohler porcelin sink. How do I? Will a steel drill bit work? The hole is for a filtered water faucet. 1/2 inch dia.
wazeaz is offline   Reply With Quote
Old 03-17-2008, 07:31 PM   #2
Building and plumbing
USP45's Avatar
never tried it. may work, may not. lets see if Ron might have an idea. he has some good insight on things.
USP45 is offline   Reply With Quote
Old 03-17-2008, 08:31 PM   #3
Journeyman Plumber
Ron The Plumber's Avatar
Your not going to drill a hole in porcelain, it's like glass, it will do nohting but chip and shatter on the surface.
Why not mount the filter water spout on the counter top, next to the sink. or get a new sink that has the extra hole in it.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 03-17-2008, 11:14 PM   #4
Send a message via AIM to Marlin
I would imagine you could drill porcelain with a diamond hole saw.
Marlin is offline   Reply With Quote
Old 03-18-2008, 02:38 AM   #5
I blame ProWallGuy
Imaging and doing are two different things. If this sink is enameled cast iron, the enamel is very thin and very fragile when not in full contact with the cast iron. The surface is quite hard to resist shock from above. Drilling it with any sort of hand drill, even diamond can cause it to shatter because its so thin and once the surface is penetrated, the edge of a bit that is moved or spinning out of balance or true to its own axis will contact the adjoining surface and blow it out. Drilling the cast iron has it own set of problems too. Heat must be controlled or the cast iron will expand or contract faster than the enamel or vice versa and you will get a shatter of the enamel. Just like putting cold water in a hot coffee pot.
Its a very technically challenging thing to do and most pros would even consider it. You run a higher risk of replacing the sink than getting a hole in it unscathed.
If its all porcelain or clay, you might be able to drill it, but I wouldn't risk the sink unless you're willing to replace it.
I'd replace the kitchen faucet to free a hole if possible, or install the dispenser in the counter top.
Double A is offline   Reply With Quote
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 08:07 AM
Sink Depth dilemna Yippee Plumbing 9 01-01-2008 01:25 PM
Sink hole under garage slab. diggitydog Building & Construction 3 08-31-2006 01:49 PM
stainless steel kitchen sink KANUTTER Plumbing 6 01-09-2006 04:42 AM
Countertop sink hole Grebus Remodeling 1 08-31-2005 11:09 PM
