I have a wall mounted toilet in my basement that ties into the vertical vent stack and doesn't flush right. It takes two or three flushes to remove waste with 2nd/3rd flushes being more powerful than the 1st which leads me to think I have a venting problem.
The previous owners have it vented via AAV vent in the branch as opposed to the stack. The stack is vented from a sec floor bath but I suspect the AAV being tied in the trap/branch could be the problem. Appreciate an opinion based on the drawing if the AAV would even help where its located currently.
Also note it uses a sloan flush valve which may need an adjustment? thanks
