-   -   Draining wshing machine/ sink to sump. (http://www.diychatroom.com/f7/draining-wshing-machine-sink-sump-164057/)
tedennis 11-19-2012 06:28 PM
I have our washing machine in our basement and have had it draining to a floor drain. I will be honest in saying I dont think I should be doing that. But I dont know an aternaive. Hopefully you guys can help.
We bought the house and had to have foundation issues fixed. I replumbed the whole house with PEX at this time. A sump was installed with primary and backup pumps. It is about 20 feet from where washer hookups are located. I want to know if it would be ok to run a pipe, probably 2 inch, from washer to the sump. I would run a pipe with a funnel up to the washer heght and mount to the wall, run it down and install a tee where the sink would drain into, and then run it to the sump, at downward angle of course. Is this up to code?
I am on city water/sewer. I dont know where the floor drain drains too. There is standing water in it and this is what scares me. It has not overfowed. It doesnt seem to smell.
Thanks for the help ahead of time.
gregzoll 11-19-2012 06:34 PM
Mine drains into the floor drain. Been that way for years with no problems. Previous original owner had it that way, when we bought thw house, so I left it that way.
Too much work to cut the floor and run a drain to the mainline.
gregzoll 11-19-2012 06:35 PM
Run water and see if it goes into thw sump. If not, it goes to city sewer.
tedennis 11-19-2012 06:49 PM
I know the floor drain does not drain to the sump. I have read in other posts it could drai. To main line or to stones under floor.
I guess I just didn't think having an open drain was up to code or sanitary for that matter. I want to cover drain up because right now I could stick my foot into it.
Maybe the drain just needs cleaned out.
ben's plumbing 11-19-2012 08:38 PM
find out where drain is connected...should be main sewer...cut concrete from drain in floor to laundry center install new drain ..cement back up ..to code and done properly..ben sr
gregzoll 11-19-2012 09:31 PM
Ours, we place a bucket upside down over it, even though it sits next to our stairs. As for plumbing it properly, keep in mind that you are going to have to pull permits when you do the work.
