Draining Water In Well - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-19-2009, 06:20 PM   #1
learning
draining water in well
Any ideas how I can drain water down into the well supply pipe? This is a seasonal cabin on solid limestone so not practical to dig down to the frost line. Was told to drill a small weep hole a few feet down into the pipe but what happens if that hole gets clogged? Someone else must have a solution that is not involved and trouble free. Thanks for helping.
Ken0217 is offline   Reply With Quote
Old 03-19-2009, 08:22 PM   #2
Safe, Most of the Time!!
brokenknee's Avatar
At my lake place (camper) I had the well guy install a ten foot 1/2" copper pipe that went down into my well with an air fitting connected to it. At the end of the season I would just take a small pancake compressor connect it to the fitting and blow the water out through the water lines in the cabin. I never had a problem with my lines freezing.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Water softener leak - how do I set it to bypass? Cylanth Plumbing 4 07-21-2010 09:24 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 10:29 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
