-   -   Draining/Venting Tips Needed (http://www.diychatroom.com/f7/draining-venting-tips-needed-154322/)
illusion8055 08-20-2012 07:16 PM
Hello everybody,
Your input and feedback on this is very welcome.
I am combining what used to be side by side bathroom and laundry rooms in my basement into one larger room and of course this necessitates moving plumbing.
The previous plumbing all seemed to be draining just fine.
Please see the attached photos for a reference:
http://i.imgur.com/0vxwU.jpg
http://i.imgur.com/H3NLH.jpg
My main areas of concern are as follows:
  • The existing dry vent that I am tying into is 2". I presume given teh fact that there were no past problems that this is sufficient for this bath/laundry group
  • Given that the shower is now downstream from the toilet will this be an issue with venting? They will both use the sink's wet vent
  • Do all of my tie ins to the main horizontal line (shower, toilet, sink) need to be Y-shaped?
  • As you can see the two vents will tie in at the ceiling below the joists. Is the way I have it drawn out OK? Ideally I would run the line straight to both areas but you can see some stuff gets in the way so I have to make that awkward shape. This vent ties into the stack that vents the kitchen. The kitchen sink does not drain through this stack.
Please let me know if anything is unclear about my drawings.
Am I on the right path here?
illusion8055 08-20-2012 07:17 PM
Sorry that the pics were so large...
TheEplumber 08-20-2012 08:45 PM
199 Attachment(s)
can you make them smaller?
illusion8055 08-20-2012 09:56 PM
Done! :)
TheEplumber 08-20-2012 10:24 PM
199 Attachment(s)
In my neck of the woods, very little of the either piping layouts would pass code.
The shower,lav and toilet are not vented per UPC standards.
The only thing I see plumbed properly is the washer-it's vented
And yes you must use wyes on horizontal drain connections
illusion8055 08-20-2012 10:28 PM
Do u have any recommendations?
VIPlumber 08-20-2012 10:39 PM
Give us a location so we can get an idea of which code you're under.
Up here wet venting is done quite often. The problem draining the shower before the toilet, is that if there's a back-up on that horizontal line, you could have sh*t back-up into your shower.
TheEplumber 08-20-2012 10:44 PM
199 Attachment(s)
Would you pipe the lav like that?
illusion8055 08-21-2012 03:45 AM
I'm in Montreal, Quebec, Canada. Kirkland to be exact.
illusion8055 08-21-2012 01:38 PM
My mistake, it's a 1.5" vent that I'm tying into... will that need an upgrade?
VIPlumber 08-21-2012 10:52 PM
Nope.
TheEplumber 08-21-2012 11:16 PM
199 Attachment(s)
Originally Posted by VIPlumber (Post 993748)
Nope.
Didn't think you would :thumbsup:
While I can't vent as shown on some of the other fixtures- that lav is wrong by all codes
illusion8055 08-22-2012 01:49 PM
My main line is 4". I double checked.
So I Photoshopped up some shots to further clarify things, and also illustrate tying into the 4" main AFTER the bath group.
http://i.imgur.com/ZGpbr.jpg
http://i.imgur.com/IBjPd.jpg
Is there a minimum distance to maintain between tying the laundry into the main drain and the wye for the shower?
What is wrong with my proposed 2" lav drain? Could you clarify? I plan to tie it in to the main drain via a wye. It will of course be trapped. It will also serve as a wet vent for the shower and toilet.
The upstairs kitchen/dishwasher have their own vent and the washing machine would have its own vent leading to the main bathroom vent.
plummen 08-22-2012 08:07 PM
Id try to keep the washer tied in atleast 5' ahead of any other fixture to avoid issues with soap suds,then run a full 2" vent from it.
Why do you have a 2" vent drawn for sink? :)
illusion8055 08-22-2012 08:37 PM
Thanks for the great feedback Plummen.
I have the 2" wet vent for the sink to serve as the vent for the bath group (shower/lav/wc). Is that wrong?
