Draining Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-22-2011, 01:54 PM   #1
Draining plumbing
I own a very old home which has a basement sump next to water heater and boiler. I want to drain both hot and cold supplies from the floors above. My question is if I shut of the incoming supply and open the exterior garden hose bib will both hot and cold supplies drain down to the hose bib level? Guess I'm wondering if the water column will equalize through the hot water tank.
Marvel is offline   Reply With Quote
Old 09-22-2011, 06:18 PM   #2
Rewards Points: 1,442
Yes the water levels in hot and cold subsystems will equalize through the hot water tank even if the tank is below the hose bibb.
It will go faster if you open up hot and cold faucets on each branch, generally means some faucets on each floor.
Some water may stay behind in horizontal sections that are not quite level namely slope backwards a tad. Things like this result in burst pipes in winter even though you went through the motions of draining the plumbing.
The Following User Says Thank You to AllanJ For This Useful Post:
Marvel (09-23-2011)
Old 09-23-2011, 09:09 AM   #3
Thank you for your assistance. Cheers
NEW sink and plumbing is slow draining, no overflow, pipes not clogged ymi2b Plumbing 15 09-10-2015 09:29 PM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 01:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
Portable air conditioners; who's got one? (No draining! Yet most say draining req'd?) Deck Appliances 1 07-16-2008 11:33 PM
