Old 10-27-2011, 10:23 AM   #1
Draining Pipes with Air Compressor
Im a looking to winterize my house and blow the pipes out with an air compressor. The house is small. 800 square feet, with one bathroom & a washing machine. Im not looking to spend a great deal of money on a big compressor that isnt necessary. What is the smallest size air compressor would I need?
atonkennedy is offline   Reply With Quote
Old 10-27-2011, 10:31 AM   #2
Doing it myself
Alan's Avatar
The smallest one they make.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
atonkennedy (10-31-2011)
Old 10-27-2011, 05:33 PM   #3
I'd rather see you buy a small pump and pump non-toxic RV antifreeze through your pipes and put some in the toilets(tank and bowl) and traps. Blowing sometimes leaves water in low spots with the antifreeze you can open each spigot until it runs pink. Isolate the water heater and drain it. Don't forget the washing machine. I'm sure there's something I am forgetting.
COLDIRON is offline   Reply With Quote
Old 10-27-2011, 06:29 PM   #4
biggles's Avatar
simple and cheap... http://www.harborfreight.com/12-volt...sor-96068.html
Old 10-27-2011, 06:33 PM   #5
I totally agree with ColdIron, I tried with a 20 gal compressor once, after I replaced a lot of split pipes I went back to the RV antifreeze and no problems since. It is not worth the risk. or trouble to go the air compressor route unless you have a huge compressor like the people use to blow out sprinkler systems.
merle is offline   Reply With Quote
Old 10-31-2011, 11:38 AM   #6
Thanks for the responses and advice.
What do you use to pump the antifreeze into the pipes?
Old 11-01-2011, 07:12 AM   #7
First shut off the main water valve and drain everything in the house that has water in it, shut off the water heater and drain it, disconnect the washer hoses(maybe), hook up a pump to the spigot out side fill a 5 gallon bucket with RV antifreeze, stick a hose in it and have some out there to help you that can plug and unplug the pump, go in the house open one spigot at a time and tell the person to start the pump , once you see pink tell him/her to stop the pump, go to each fixture and do this then pour it in the toilet tanks and toilets by hand after you get all the water out. Not positive about the washer you might have to start the fill cycle and start the pump to keep the washer water pump from freezing. It sounds complicated and a lot of work but it's not really just take your time and make sure you think of everything where water would freeze. OH, don't forget all the traps in the house dump at least a cup in each one. You might need more than 5 gallons I'd buy 10 for the first year then each year after that you'll know the amount better. So for probably around $100 that's not bad to protect your investment. I'm sure I am missing something. Just think like water. Maybe someone else has an easier way and they will throw in their 2 cents.
Draining water out of shower pipes docmattman Plumbing 9 05-23-2011 08:43 PM
NEW sink and plumbing is slow draining, no overflow, pipes not clogged ymi2b Plumbing 6 09-22-2010 06:43 PM
Moving AC Compressor Pipes 2' WaldenL HVAC 19 09-22-2009 06:04 PM
Draining heating pipes to do work on walls RyanD Plumbing 5 06-15-2009 03:06 PM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 09:13 AM
