Draining Laundry Sink Into Washer Stack? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-30-2011, 06:09 PM   #31
Master Plumber
Javiles's Avatar
Rewards Points: 990
On top of everything else a mechanical discharge (anything with a pump) must be piped below a gravity discharge.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 12-30-2011, 07:14 PM   #32
Rewards Points: 582
they only put duct tape over the top because either water or soap suds would come out when washer is discharging....need to change entire set up to accept new tray and install vent making sure not to double trap system...ben
Old 12-31-2011, 01:46 PM   #33
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
I would remove the existing below the floor trap, reuse the drain to plumb the sink with a trap and add an AAV for the sink. Now drain the washer into the sink.
Coastal South Carolina
Old 12-31-2011, 03:02 PM   #34
Master Plumber
Javiles's Avatar
Rewards Points: 990
Originally Posted by Anti-wingnut View Post
I would still recommend getting a plumber in
1) If the stand pipe is serviced by a trap, then the location of the trap is much too low
2) We do not know if said trap is properly vented
3) If the stand pipe is serviced by a trap, what is the purpose of you adding a trap to the tub? There is none, because the drain circuit is already trapped.
4) There is no need for a "secondary vent". In fact, such an application is precluded by code. A vent should either go to atmosphere outside the house, or be protected by an AAV
What you have now is a complete mess, and should be cleaned up
Don’t you just love the way some DIY’ers Butcher the code even though they are being told how to do it correct way, if you r asking for help, do it the correct way, there is a reason why a plumbing code was put together just because you pipe something in and it works doesn’t mean it won’t have some adverse effect in some fashion down the road, . There are some things the DIY’ers should stay away from.
Tags
drain , laundry , sink
NEW sink and plumbing is slow draining, no overflow, pipes not clogged ymi2b Plumbing 15 09-10-2015 09:29 PM
Kitchen sink not draining, is it the vent? gdav Plumbing 18 02-12-2013 04:38 PM
slow draining bathroom sink brandonriffel Plumbing 6 06-17-2010 02:20 PM
vent stack for kitchen sink Knucklez Plumbing 4 04-02-2008 07:49 PM
Moved Washer, Dryer and Laundry Tub chaz Plumbing 4 11-03-2007 03:35 PM
