Draining Carbonic Acid - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-07-2010, 08:05 AM   #1
First time post:
I have a high efficiency furnace and the carbonic acid is draining through a plastic tube to the center basement floor waste drain. The sump pump pit is located on the far side of the long basement.
Due to some water/waste backup and the basement now being finished, i have purchased a plumbingsupply flood guard float model
http://www.plumbingsupply.com/floodguard.html
I assume the acid dripping onto the float will corrode the metal or the rubber float ball over time, so what's the best way to keep a valve and/or neutralize the acid? There is about a 3in space above the float valve in the pipe and surface of the floor. I suppose i could lay down a fine screen and pour some lime pellets in huh!!
justintbrown is offline   Reply With Quote
Old 10-07-2010, 09:27 AM   #2
Rewards Points: 1,536
Carbonic acid loses its potency when exposed to the atmosphere. Collect it in a wide pan near the furnace with an overflow tube leading to the drain.
You could neutralize the acid with baking soda or lime but the compounds generated in this process are equally corrosive (like salt on the metal underside of a car) as the carbonic acid itself which is actually a very weak acid compared to other acids like sulfuric acid.
Carbonic acid is what gives the fizz to soda pop.
Old 10-07-2010, 10:42 PM   #3
Plumb or Die!
I'd go to a furnace supply place and buy an acid neutralizer kit. It's a 8"ish long piece of pvc pipe with threaded caps on each end, filled with limestone chips. The caps have 1/2" female tappings. Every hi eff boiler I've ever put in has one, and you really need to have one. You have to get new chips every year or two, plumbing systems aren't meant to dispose of acids.
plumber666 is offline   Reply With Quote
Concrete: Top Cast vs. Acid Stain/Wash sportinwla Landscaping & Lawn Care 0 07-09-2010 02:15 PM
Concrete Acid Coloring Taipans Landscaping & Lawn Care 1 10-09-2008 06:45 AM
Washtub draining into floor drain DIY? Because we LOVE you Plumbing 2 08-26-2008 09:48 AM
Portable air conditioners; who's got one? (No draining! Yet most say draining req'd?) Deck Appliances 1 07-16-2008 10:33 PM
Rain water draining into sump pit ERIK2173 Building & Construction 19 07-20-2007 09:19 PM
