Drained Water Heater...now No Hot Water! - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-24-2010, 05:03 PM   #1
Rewards Points: 150
Drained water heater...now no hot water!
Yup. Drained the water heater and five hours later I don't have hot water...just air then nothing. I turned power back on (electric), turned cold inlet back to open, closed the drain valve and vent valve...my wife thinks I'm crazy...what did I do?
joemontana16 is offline   Reply With Quote
Old 11-24-2010, 05:06 PM   #2
HVAC / Plumbing
did you turn off the power b-4 you drained it ? If you didn't you possibly burn out the elements. Turn on the fixtures and let all the air bleed out. you could have stirred up all the junk and stopped up 1 of the fixtures. try the tub
kenmac is offline   Reply With Quote
Old 11-24-2010, 05:29 PM   #3
Rewards Points: 36
You also need to be sure that the heater is totally full of cold water before turning power back on.Open water inlet,turn on hot taps till water flows then turn power on.
daveb1 is offline   Reply With Quote
Old 11-24-2010, 06:23 PM   #4
biggles's Avatar
so you turned the power on then the cold water feed..shouldn't of touched the power till you had flow out of the faucets..if the heaters aren't submerged in water they will burn out when the water hits them so the cold water is dropping in from the top and hitting the elements
Old 11-24-2010, 06:37 PM   #5
Rewards Points: 150
I think the inlet valve is failing. The valve spins and does not stop...I think its stuck closed.
Old 11-24-2010, 06:54 PM   #6
biggles's Avatar
if you have no water out of the drain connection valve its empty..but those heaters are shot if the power is still up after 5 hours
Old 11-24-2010, 07:20 PM   #7
HVAC / Plumbing
If it's a gate. it's possible that it broke
Old 11-24-2010, 11:10 PM   #8
Rewards Points: 150
Thanks for the help guys. I think I got extremely lucky. It's a Thanksgiving miracle! No, really...I turned the power off and waited a few hours for the elements to cool. Then I played around with the inlet valve and got it to open...hot water!!!
Old 11-25-2010, 05:22 AM   #9
Rewards Points: 36
Glad it worked out for you.Might have taken some life out of the elements.Remember to replace that valve next time you need to work on the heater.Have a good Thanksgiving.
Old 11-26-2010, 07:41 AM   #10
Rewards Points: 1,512
Originally Posted by daveb1 View Post
You also need to be sure that the heater is totally full of cold water before turning power back on.Open water inlet,turn on hot taps till water flows before turning power on.
Worth repeating.
Condensation on ceiling near water heater. EkS Plumbing 5 10-12-2010 10:48 PM
Raising Water Heater Tank doesntmatter Plumbing 6 09-30-2010 09:05 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
Tankless Water Heater welshie Plumbing 12 03-03-2010 12:46 PM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 05:58 PM
