Drainage Tile - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-24-2008, 09:09 PM   #1
drainage tile
I need to add drainage tile to my back yard. I plan on running it to a dry well. I don't need to be doing anything fancy because the problem is not a major one.
I know that the tile I use needs to be perforated and I am used to foundation tile that is only perforated on the bottom half. I have access to some free flexible drainage tile but it has perforations all around. Am I able to use this opr am I going to be digging it up in a few years to replace it because it is clogged?
Should I just get a sleeve to keep dirt out?
Should I surround it with gravel?
How deep should I bury it?
Any useful information on this would be appreciated.
steel is offline   Reply With Quote
Old 07-25-2008, 09:08 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I assume that you're doing a French drain of some type.
If so, you need to slope the drain tile about 1/4" per linear foot to your drywell. It doesn't need to buried deep.
The drain tile should be perforated on the sides only IMHO, and placed in gravel with a fabric sleeve over it.
You're right. If you don't put a sleeve over it, it will be clogged in short order.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-26-2008, 10:07 AM   #3
Thanks Mike
I was hoping it didn't have to be buried deep. I guess I'm going to have to suck it up and buy the right tile myself. I was hoping to get off cheap but beggars can't be choosers I guess.
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
