Old 07-07-2008, 03:44 AM   #1
Drainage systems
Hi All
one of my cline has recently changed his double drain sink with a single drain sink.
I now need to redo all the plumbing to allow for single drain usage.
I am having a hard time trying to find what is the proper way to install the disposal and dishwasher to a single drain,
and at the same time what is the proper layout of the PVC piping.
we will highly appreciate your feed back.
Thanks in advance.
james.parera is offline   Reply With Quote
Old 07-07-2008, 04:33 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Drainage systems
The disposal is obviously installed on the single drain sink. The disposal unit should have a short dishwasher "pipe" for the dw drain hose to slide onto for double-clamping with ring clamps from the air gap (if required by code in your jurisdiction).
Don't forget to knock out the plug with a screwdriver and hammer on the disposal before attaching the dw hose.
The disposal then drains through a trap.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-07-2008, 05:40 AM   #3
Drainage systems
Thanks Mike
Comparison of subfloor waterproofing systems formarley Building & Construction 5 10-22-2009 11:03 AM
Drainage issue and need suggestion on type of grass golfer2b Landscaping & Lawn Care 9 03-24-2008 08:38 PM
Drainage issue from heating system and washing machine susandlynn Plumbing 1 11-17-2007 03:28 PM
Building a drainage ditch get outside Landscaping & Lawn Care 5 05-15-2007 03:44 PM
