Old 01-10-2011, 06:43 PM   #1
Question
Drainage problems kitchen sink only.
Second floor kitchen sink won't drain. Ran 50 feet of snake with no apparant obstructions and also ran 20 ft down vent pipe from roof vent just overhead kitchen roof. Rehooked sink pipes to wall drain, filled sink with water and it stops draining after 1 inch or about a gallon once released. I'm clueless. Any Ideas?
Raytanner is offline   Reply With Quote
Old 01-10-2011, 08:00 PM   #2
Owner
LateralConcepts's Avatar
You most likely went right through the blockage (grease/sludge). You need to run it back and forth in a scrubbing motion within the first several feet or so. Put some bends in the end of your cable so it looks like this: VVVVV
If you don't want to keep messin' around with the trap, fill the sink with water, and have someone watch or listen as you cable from the roof vent.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS,LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
LateralConcepts is offline   Reply With Quote
Moving kitchen sink teachtech Plumbing 4 08-08-2010 11:13 PM
Kitchen sink centered on cabinet? sillyboy22 Plumbing 3 03-02-2010 10:16 PM
Smell Under Kitchen Sink mamaerin General Discussion 4 09-23-2009 12:01 PM
Kitchen sink...what do you think? Eck4Life Remodeling 5 09-02-2009 11:45 AM
Help: Kitchen sink drain is clogged with grease cips Plumbing 4 08-10-2009 11:11 AM
