Old 06-08-2009, 12:24 PM   #1
drainage pipe
HI,
I have a 50 year old home. It was recently inspected and the inspector recommended having the washer drain pipe replaced. According to the inspection the pipe is not connected to the main but rather drains into a hole in the concrete (not sure where it goes from there). Has anyone come across a drain like this?
trudi is offline   Reply With Quote
Old 06-08-2009, 12:42 PM   #2
drainage pipe
How far away is the main sewer line from this washer drain?
redline is offline   Reply With Quote
Old 06-08-2009, 12:56 PM   #3
drainage pipe
about 7 feet away
what type drainage pipe to use on a gravel way markstrt339 Building & Construction 1 11-30-2008 05:30 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 06:40 PM
Building a soffit around a drainage pipe along the wall ssudha17 Building & Construction 12 10-04-2008 04:18 PM
Heavy-duty roots in ground drainage pipe proofer Plumbing 11 08-06-2008 05:42 PM
Drainage issue from heating system and washing machine susandlynn Plumbing 1 11-17-2007 03:28 PM
