Old 11-17-2007, 10:30 AM   #1
Drainage issue from heating system and washing machine
Our heating system has a pipe for condensation removal (I assume) and runs through our basement to our laundry room, and shares the same pvc pipe that our washing machine drainage hose goes into as well. The pipe for the heater is a small clear flexible plastic pipe, and the drainage pipe is a basic black flexible pipe. The 2 are sharing the same pvc pipe, the heater pipe is being crimped due to the size of the drainage pipe, therefore causing a back up. How do we resolve this without replacing the pvc pipe? Can we use a wye attachment?
susandlynn is offline   Reply With Quote
Old 11-17-2007, 03:28 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Yes put in a wye, that should work.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
