Old 06-13-2012, 09:21 AM   #1
Drainage hole in basement backs up (caused by pump filter?)
Hello,
I recently purchased a new home (its about 15 years old). The house is on its own septic and well (no city water). In the basement near the well pump there is also a large blue container that I've been assuming is some sort of filter. Additionally there is a hole in the floor that the filter has a nozzle going to. My assumption is that the filter rinses itself out every so often (seems to be every ~30 days or so).
Image here: http://imgur.com/nWC8G
The problem is, every once in awhile this seems to backup. Instead of the water leaving the house, it goes into the basement (not very much, but I would like to fix it).
So I guess my two questions would be:
1. Any suggestions on how to go about fixing this? From what I have read a sumppump may do the job (which I may do anyway), but I've heard that I should be able to clear this up other ways?
2. What is the large blue container? Is it a filter?
Thanks!
zenox is offline   Reply With Quote
Tags
basement, pump, water
heat pump filter drier s1969e HVAC 2 01-05-2012 04:17 AM
How to Fill BIG Hole Against Basement? Fisher252 Building & Construction 4 09-17-2011 07:13 AM
Basement Bathroom Ejector Pump Barney4 Plumbing 0 08-10-2011 08:37 AM
How to design plumbing drainage in basement sonicsmooth Plumbing 0 02-02-2011 02:55 AM
Heat Pump Filter Dryer bobolink2000 HVAC 4 05-16-2010 04:53 PM
