Old 03-07-2007, 02:07 PM   #1
Drainage Code and Question
I have tried reading the code book and it is greek to me. My question is what size drain do I need for a toilet? What is the drop rate (1/4 per foot i think)? and do I need a vent for the toilet and a seperate vent for the tub/sink/shower?
Located in Ohio
rodg2915 is offline   Reply With Quote
Old 03-08-2007, 08:24 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Here under UPC, which you probably don't use that code. slope to 1/4" per ft, and each fixture requires it's own vent.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Accessable attic & Junction boxes (NEC question) IvoryRing Electrical 7 04-10-2013 10:30 AM
Code requirement to replace bathroom window. Rem8 Building & Construction 5 06-16-2008 03:57 PM
code question JustJoe Building & Construction 3 01-27-2007 10:06 AM
