Drain For Washing Machine - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-28-2011, 09:24 PM   #1
Drain for washing machine
I have a drain pan underneath my washing machine on the second floor of my house. I have had washer problems, lots of water, and now need to pull up the pan to get the water dried up. I have removed the four screws that hold it to the floor, there is a white ring sitting under the screem for the drain and I cannot get the pan to come up. The whole conduit is moving, how to I detach the pan from the drain line itself?
dad3boys is offline   Reply With Quote
Old 06-29-2011, 06:54 AM   #2
Rewards Points: 1,548
Don't detach the drain pan any further. Wedge the outer edge to be perhaps a quarter inch above the floor (don't force it) and bloe a hair dryer under there for several hours. Repeat on the next side, then the third side, etc.
You canb also use a coat hanger wire and push a towel under the wedged up drain pan to sop up any significant amount of water before using the hair dryer.,
Old 06-29-2011, 09:36 AM   #3
Does that mean the pan is glued to the drain? I'm imagining pcv glue?
Bloke is offline   Reply With Quote
Old 06-29-2011, 09:39 AM   #4
dont the screws through the pan into the floor kinda defeat the purpose of the pan or were they sealed? a picture would be most helpful
washing machine drain pan mark123 Plumbing 9 09-08-2010 06:50 PM
Drain Pipe to Washing Machine houston81 Plumbing 10 07-07-2010 06:39 PM
Plumbing a Washing Machine Drain MikeWood Plumbing 2 01-21-2010 07:10 PM
washing machine drain vent problems rebelbull Plumbing 7 03-29-2009 09:18 AM
Condensor drain Captflx HVAC 6 08-17-2008 10:19 AM
