Drain And Vent Questions - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-02-2010, 03:30 PM   #1
RustyRealtor's Avatar
Rewards Points: 283
Drain and vent questions
Hello All - and Happy New Year!!
I am installing two new bathrooms in my house and I am not sure where to place the vent(s). I am hoping to get away with one vent. I've attached a sketch of the drains and I wonder if you good folks can tell me if this is a feasible layout? Also, where should I place the the vent pipe(s)?
Many Thanks,
Russell
Thanks,
Russell
RustyRealtor is offline   Reply With Quote
Old 01-03-2010, 11:12 AM   #2
Russell, the sketch should have lengths of run shown before anyone can recommend vent location (s). There are 'critical distance to be considered between the traps and vents. Also wall location would be helpful and wall thicknesses 2x4 or 2x6? Cleanout need to be provided also. You might want to look at AAV's (studo-vents)
geoffrey hall is offline   Reply With Quote
Old 01-03-2010, 11:15 AM   #3
Russell, the sketch should have lengths of run shown before anyone can recommend vent location (s). There are 'critical distance to be considered between the traps and vents. Also wall location would be helpful and wall thicknesses 2x4 or 2x6? Cleanout need to be provided also. You might want to look at AAV's (studor-vents) in a couple locations.
Old 01-03-2010, 08:12 PM   #4
Rewards Points: 283
Thanks for the reply, Geoffrey
I will Make the changes to my drawing and post anew.
Russell
Thanks,
Russell
Old 01-03-2010, 11:55 PM   #5
Rewards Points: 283
Hello Again,
I have attached another version of my drains, including length of runs and walls. The house is of frame construction with a bit of a crawl space. The floor has been removed, so I can easily move around. I have considered AAV, but I'd like to avoid them if I can. I don't mind having two vents and if two are needed, I thought I would join them in the attic so as to have only one roof protrusion. I still am unsure where to put the cleanout(s). Do I need one for each toilet?
Any advice is greatly appreciated.
Thanks,
Russell
Installing stand-up shower in finished basement without existing drain notenoughtime Plumbing 3 05-16-2009 12:59 PM
toilet wet vent questions (with sketch) Queso Bandit Plumbing 3 03-28-2009 08:15 PM
Sink Drain Pump Vent Handyman101 Plumbing 0 03-11-2009 12:43 PM
AAV or Studor Vent Needed for this Tub and Shower Drain? BillyDIY Plumbing 1 12-17-2008 12:11 AM
